How do I use the Arlo Baby music player?
This article applies to:
You can use the Arlo app or the button on the right side of the camera to play and pause the playlist of sounds, music, and lullabies on your Arlo Baby. You can also use the Arlo app to perform the following actions:
To play or pause sounds and music using the music button:
Press the music Music buttonbutton on the side of Arlo Baby to play or pause.
To play or pause sounds and music from the Arlo app:
  1. Launch the Arlo app or log in to your Arlo account at my.arlo.com.
    The Devices page displays.
  2. On your Arlo Baby camera feed, tap or click Music player icon to access the music player controls.
  3. Tap or click Play icon to play or Pause icon to pause.
To adjust sound and music volume:
  3. Tap or click Volume icon to access the volume control, then move the slider up or down to change the volume.
  4. Tap or click Volume icon again to close the volume control.
To play a single track on a loop:
  3. Tap or click Playlist to access the playlist.
  4. Tap or click Play icon next to the sound or music that you want to play on a loop.
  5. Tap or click Close.
  6. Tap or click Loop to loop the track that is currently playing.
    This track plays on a loop until you turn off the music player or until the timer completes if you set a timer.
To change the order of sounds and music in the playlist:
  4. Tap or click Edit and reorder the tracks:
    • If you are using a computer, click and drag tracks to a different place in the playlist.
    • If you are using the Arlo app, press and hold Hamburger menu  to the right of the track that you want to move, then drag the track to a different place in the playlist.
  5. When you are done editing the playlist, click Close or tap Done.
To inable or disable shuffle for the tracks in the playlist:
  3. Tap or click Shuffle to enable or disable shuffle.
    The playlist plays on shuffle until you turn off the music player or until the timer completes if you set a timer.
For more information about the Arlo Baby music player, see the following knowledge base articles:
Last Updated:08/25/2019 | Article ID: 1282527
Was this article helpful?
image description Yes image description No
Arlo Community
Learn from other Arlo users like you and experts that are offering up best practices and answering some common questions. Get involved and suggest your own topics to discuss as well.
Ask the Community
Contact Us
Have additional questions? Try our live chat or give us a call. Our team of Arlo experts is ready to answer your questions and help in any way that we can.
Contact Support
