This article is for the Arlo Secure App experience with Library. If you have the Arlo Secure App experience with Feed, please visit: How do I filter events and video recordings in my Arlo Feed?
You can use the filter to find and view recordings based on criteria that you select.
To filter your library content:
- Launch the Arlo Secure App or log in to your Arlo account at my.arlo.com.
- Tap or click Library.
- Tap or click the Filter.
- Tap or click the filtering criteria that you want to use.
- Tap or click Done.
Your Arlo library is now filtered according to your selected criteria.
When you use filters, only the recordings in your library that match your filter criteria display.
To turn off filters in your library:
- Tap Reset to remove your filter(s).
Last Updated:11/30/2022
Article ID: 45
