Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Arlo Pro 2 - Clarity and Compatibility question
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Will the Arlo Pro 2 1080p camera work with the Alro Base Station that came along with the Arlo Pro? Also, is the clarity of this camera sharp enough to see an incoming cars license plate as it passes by?
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes and "It Depends" (TM).
With a 130 degree angle of view, these are not ID cameras. If close enough, you'd be able to see details but download any 10mm fisheye lens image from the Internet and try the same thing when sampled to 1280x768 since the lenses are similar.
Related Labels
Arlo Mobile App
493 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
954 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,099 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,926
