Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Arlo Pro 2
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can the Arlo Pro 2 be used in a cold storage freezer at -15F? Should it be wired or can it run on batteries? Don't need it for alarm but just to view operation.
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The P2 is similar in specs to the Pro. Both are rated down to -4F and the Pro is known to turn off at that temp.
Related Labels
Arlo Mobile App
491 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
954 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,097 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,924
