Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Attention: Subjects not in the form of a question may be removed and not answered.
Reply
Discussion stats
  • 1 Reply
  • 3327 Views
  • 1 Like
  • 2 In Conversation
BretD
Arlo Employee Retired
Due to the huge volume of responses to this AmA topics with subjects not in the form of a quesiton will be removed from this board and not answered. This will also cancel your entry. Please read the questions submitted. We are getting a large number of duplicates. Here are answers to some of the most common questions:
Will you be offering a Camera Exchange for Existing Arlo pro users? (No)
Will CVR and 3 Second Look back work with the Solar Panel? (No)
Is it compatible with existing Base Stations? (Yes)
How is the Picture Quality? (1080p vs. 720p, depending on connection strength, lighting and other factors. We will post a comparison soon.)
Can you use the CVR outdoors? (Not supported)
Do the Existing Accessories for Pro work? (Yes)
How do Activity Zones work? (Must be plugged into power.)
How is the battery utilized when doing 1080p? (Great, similar to Pro)
____
Please click KUDOS or REPLY If you found this helpful.
1 REPLY 1
Bosox4
Will the Arlo Pro 2 system come with a dedicated power supply for each camera and have a longer battery life than the Arlo Pro?
Discussion stats
  • 1 Reply
  • 3328 Views
  • 1 Like
  • 2 In Conversation
