Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
1 of 5 cameras does not detect/record motion
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have 5 cameras. Four work correctly. One camera does not detect motion, and thus does not record on motion. It does detect audio, and will record on audio. Live view on the camera is fine. All of the settings on the problem camera are set exactly the same as the settings on the 4 cameras that work.
Labels:
- Related Labels:
Troubleshooting
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Go into modes and make sure that the motion is detected box is checked.
Use the motion detection test under settings to see if the camera led flashes with movement.
If this does not work then remove the battery for a few seconds and then replace to reset the camera.
You could also remove and resync that camera and see if that works.
Related Labels
Arlo Mobile App
491 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
954 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,097 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,924
