30 minute timeout?
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Does the Arlo Pro 2 timeout automatically after 30 minutes like the Arlo Pro does? I'd like to use as a baby monitor. I had the Arlo Q cameras and they were garbage with connectivity and kept dropping the feeds and were too unreliable to use as a baby monitor.
I would keep it plugged in constantly, 24/7.
I have an Arlo Pro base station and two cameras for outdoor monitoring already. If there is no longer a timeout issue, can I use my existing base and just add the Arlo Pro 2 camera?
BTW, I understand a timeout on the Arlo Pro cameras if on battery, but when plugged in this should not happen.
- Related Labels:
Before You Buy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Honestly...a good question.
Don't know... As the Pro2 while plugged in IS recording all the time, not sure if the app/web software will time you out.
Someone will have to test this.
ask again in a couple hours 🙂 , I'll start a test.
( as to the Q, I find it to be one of the better cams from Arlo... good rez and don't think mine has dropped out in over 2 years ) YMMV
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Appreciate the response!
Here's a thread I made in the Arlo Q forum discussing my issues with it. Was just incredibly unreliable.
The quality of the streams and the consistency of the Arlo Pro is much better so I was really hoping this would work. I don't want to go back to the fuzzy baby monitor! I tested the Pro last night and it timed out 30 minutes on the dot. I'd happily swap them out for two Arlo Pro 2's if there was no timeout.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Ok... set the ac powered Pro2 up and running .... at 25-26 mins it was still going.
At 45 mins of run time, I got back to it and it had timed out ( web prgm stated it had ).
Goin to guess it times out at the 30min mark +/- like all the others
PS read thru the prev thread, can't say I have used it for a baby monitor ( as I have an Arlo Baby ).
but I did test it in the past for timing out and after an hour or two, turned it off ( this was over a yr ago and a lot can happen in FW )
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I was afraid that would be the case. Appreciate you checking into it.
From what I've read about the Arlo Baby I'd likely have the same issues that I have with the Q. Looks like we're going back to the old fuzzy baby monitor.
Thanks again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Find the quality of the Baby very similar to the Q... both very good..
Here's a snap shot of quality;
Arlo Mobile App
493 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
954 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,099 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,926
