Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
5ghz in cameras yet?
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Does the Arlo Pro 2 hardware (base or cameras) support 5ghz yet?
Labels:
- Related Labels:
Before You Buy
4 REPLIES 4
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No..the base uses only etherent, the cameras use 2.4ghz to the base for better range.
Only the Arlo Q cams and Baby use 2.4 or 5 ghz ( hook directly to your wifi without base )
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The likely reason for using 2.4GHz is the increased range possible. The higher the frequency, the more easily the signal is blocked.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
As above, not just range as in distance but 2.4 has a better ability to pass through building materials
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Why would you want 5GHz?
Do you have a problem that needs fixing?
Just another user
Arlo hardware: Q Plus, Pro 2 (X2), Pro 3 (X3), Pro 3 Floodlight, Security Light (X2), Ultra (X2), Doorbell, Chime
Related Labels
Arlo Mobile App
494 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
954 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,099 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,929
