Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Just purchased and setup a 5-camera Arlo Pro 2 suite - and realized that I need to add another 3 cameras to the array. Noticed that the Pro-2 cameras are pretty pricey as individual add-ons and was wondering if the older Arlo Pro cameras would integrate with the Arlo Pro-2 base/User interface. Are they compatible with the Pro-2 Base?
Solved! Go to Solution.
Labels:
- Related Labels:
Installation
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes... The Arlo, and Arlo Pro will function on the Pro2 base
Morse is faster than texting!
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Related Labels
Arlo Mobile App
488 -
Arlo Pro 2
11 -
Arlo Smart
148 -
Before You Buy
951 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,097 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,905
