- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi,
I have recently installed a Pro 2 camera looking down my driveway, which also has a LED PIR security light from Amazon installed. The camera is positioned out of range of the PIR sensor on the light, but last night the security light would not turn off. As the only thing that changed was the installation of the Arlo Pro 2, I'm assuming there is some interference from the camera causing the light to trigger. Would turning off the night vision on the Pro 2 stop it from emitting IR, and therefore stop it triggering the light? (the camera is not hardwired in, but running on battery power)
Solved! Go to Solution.
- Related Labels:
Troubleshooting
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The easy thing to do is try it... tho it doesn't effect my Cam/Light combo and they are in each others range ( about 10 feet apart )
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Solved it- it turned out to be a faulty light which was randomly triggering. I only noticed it though with the install of the cameras..
thanks for for your help
Arlo Mobile App
494 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
954 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,099 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,928
