- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Looking to purchase a 2tb backup hd from Amazon. I understand 2tb is max size and the need to format fat32. However, during a chat with tech support, it was mentioned to me that other customers were having issue with WD branded units but rep couldn't endorse a particular brand. Can anyone give a recommendation? Seagate? I searched but didn't really see any brand names mentioned nor did I see any complaints regarding a brand. Thanks in advance.
Solved! Go to Solution.
- Related Labels:
Service and Storage
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
@ckm705 wrote:
Thank you for the response. Yes I am aware of the need to download the videos. I am just asking for brand recommendations.
Just wanted to make sure you wouldn’t go for a large capacity hard drive for the wrong reason. I’m using a 32GB usb stick and it’s now storing over a year’s worth of 5 cameras videos.
Previously I had tried a seagate 1TB portable hd, worked fine too, but I thought it was an overkill and much wasted space.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2TB is generally gross overkill. Also, a hard drive is harder to remove and replace than a thumb drive. I have tried both and much prefer using a thumb drive. Choose the capacity for what you need - I use a 16GB one and it will typically not fill for 2-3 months with many recordings a day. 64-128GB would last a long time. If you really want to preserve all those videeos, pull it out on a schedule and copy them to a hard drive for permanent storage.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for the recommendation. I appreciate the quick respnose. I have to be honest with myself knowing I won't want to remove and download that often, regardless of how minute a task it may be. I kinda want to be able to forget about it. With that much storage, I'm hoping it'll have a long enough history for almost any situation I'd need to look back on. Also, at approximatley half the cost, a 128GB stick will not hold half the recordings that a 2TB drive will.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Please note......you still need to “download” videos from any type of usb device you end up using. You will have to move it (hd or memory stick) to a pc in order to view video clips. You cannot access them directly from base station.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I would expect any name brand hard drive that's externally powered would work fine.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That's what I originally thought but as I stated in the OP, rep mentioned reported issues with WD. Thanks for the reply.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Got it, thanks. Wow, you're getting a years worth with 5 cameras on 32GB? With the amount of activity I have, I'm calculating approximately 300 days with 5 cameras on a 2TB drive. I kinda just want to forget about it but be able to access them if the need were to ever arise. Since there were no suggestions I ordered a Seagate so we'll see what happens. Mahalo.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yeah......only two of the five cameras are somewhat busy, other three very low volume.😊
Arlo Mobile App
494 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
954 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,099 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,928
