Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Arlo Pro and Wink Hub 2
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Does the Wink 2 Hub work with the Arlo Pro 2 units. Since it works with Arlo Pro I assumed it would work with Arlo Pro 2. Any help?? Thanks!!
Labels:
- Related Labels:
Troubleshooting
3 REPLIES 3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If the Pro works with Wink, there is no real reason why the Pro2 won't...
The Pro2 is the same basic unit with extra features when on ac power .
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
according to wink they asked us to reach out to netgear as of now it does not work in wink.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Definitely not working with the Wink2 hub yet. Just picked up the 2 cam set today, and got one setup and configured, then tried the Wink connection and it says no cameras can be found when I try to add it. Hopefully, this gets worked out soon.
JKC
Related Labels
Arlo Mobile App
488 -
Arlo Pro 2
11 -
Arlo Smart
148 -
Before You Buy
951 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,097 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,905
