- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi,
I was asked for the Base firmware update today. Since that the Apps and web say the Base is offline. I have tried to switch it off and on, check the cables and Internet connection. Everything is fine, the base has three solid green lines and seems to work perfectly. Still - according the apps it is offline. Any help or suggestions, please?
Solved! Go to Solution.
- Related Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
After the random assortment of firmware updates, one of my Arlo Pro 2s continues to generaly display the "This Arlo device is offline" message. The camera sporadically comes back online, but then reverts to displaying the offline error message. The firmware doesn't seem to display consistently, so I've listed both that I've observed. The other Arlo Pro 2 camera appears operational. I did not experience the base station offline issue that seems prevalent in this topic. Here is the requested information:
ISP: Comcast
Arlo Pro 2
Firmware: either1.125.8.0_19174 or 1.125.5.0_17202
Hardware: H3
Status: Not Operational
Error message:This Arlo device is offline
Arlo Pro 2
Firmware: 1.125.8.0_19174
Hardware: H3
Status: Operational
Pro Base Station:
Firmware:1.10.0.4_20963
Hardware: VMB4000r3
Status: Operational
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ISP: RCN
Base station hardware: VMB4000r3
Two cameras hardware: H3
Everything says off-line.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
so after disconneting and reconnecting 5 times, i was finally able to get my base station connected and my cameras working. so basically i unplugged the power and internet connection...deleted all devices from my profile, then i set up the whole system again. it was a hassle but got it working now...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Any update to when this will be fixed ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The engineering team is continuing to deploy fixes resolving issues for users experiencing base station offline. If you continue to see this issue. Please reach out to me in a private message with your email address and I will escalate your information to the engineering team.
We sincerely apologize for any inconvenience this has caused and appreciate your understanding.
Click here if you need help sending a pm: Private Messenger
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Port 123 on the router shouldn't be blocked to arlo.netgear.com but that likely isn't your problem. Check the timezone for the base in Settings, My Devices. Maybe set it differently and then back. Restart the base also.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You don't see your base when using Settings, My Devices? What do you see?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Is there anybody else still offline this their ARLO PRO ???
Been ofline since the 14th and have tried everything with no luck !!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Ifanj72,
Is the base station showing offline or just the camera? What have you tried so far?
You might trying plugging the camera in and resyncing.
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi James ,
1. I have turned basestation off numerous times off and on.
2. . I have deleted cameras numerous times and reinstalled with no luck.
3. I have done a hard reset with no luck.
System comes on every 2 -3 hours with a couple of videos of motion even though cameras where deleted .
4. Every time I try and pres UPDATE For basestation it shuts down unit and says it’s off line and middle light continues to flass , hard green for power and amber on far left for camera .
On my phone up and on PC continues to show that an update from the 11th of May available :
Update 1.10.0.4_20963
Currently 1.9.8.0_16666
Soon as I press update on phone up or on PC the basestation shows amber or green for first light , amber for middle light and camera light far right goes amber or no light at all .
Base station serial number
4RE2797LA03BC
BASED IN AUSTRALIA
Then also in every attempt to update it also changes time zone and reshuffles order of cams
My email address is ivan.fanjek@aidacare.com.au
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Arlo has worked perfectly since being installed OCT 2017 and have never seen an update request on my phone app or on PC before .
Update on Phone on MAY 11 did not give me an option to update just said that both basestation and cameras needed firm wear update which I proceeded to press YES and basically immediately started showing that basestation OFF LINE
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Is this an ARLO PRO or PRO 2 ?
Is anybody else having this continued issue since MAY 11th update of basestation update ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
“ A firmware update is required for your basestation and camera “
“ let’s start with the basestation “
GREEN BUTTON “Lets update basestation “
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
A solid amber Camera LED means the base needs to be claimed. Since this seems to come and go, I'd suggest resetting the system and start fresh. Remove all devices from Settings, My Devices. Perhaps press the reset button on the base until the LEDs flash amber. Use the Add Device button on the Devices tab to claim the base. Sync the cameras. Check for firmware updates.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks I have done that multiple times.
I have removed all devices , basestation and 4 cameras from app.
Have powered down basestation multiple times .
Conducted full reset of basestation .
Loaded basestation and cameras again multiple times .
All will work BUT still showing base and cameras need update and base showing as offline , and devise continues to show that May 11 update needs to be downloaded !!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Re previous messages my Arlo Pro has now been offline since May 11th / 10 days and have tried every solution suggested .
Can we please have an update .
I have also opened a case number 30154881 and was told in the chat that this was a continuing and widespread issue but have not been notified what’s the problem or when will be resolved .
Never had a problem with my arlo basestation or camera’s before , All has been a great system up unitll May 11th.
Please let me know what is going on , surely you can have a look at my system remotely as it’s connected and you have my serial number ?
Thanks 🙏🏻
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Issues all started from last update , before that perfectly good system and did not have a single issue , worked perfectly .
WHERE IS EVERYONE LOCATED WITH THESE ISSUES ??
I’m in Melbourne Australia
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Has been a absolutely perfect system UNTILL the May 11 update .
I have reported the issue multiple times on here and to support and I’m sure there are many others with the same issue with no fix yet .
Very expensive camera / security set up that we rely on that now does not work .
need a fix or explanation please .
Arlo Mobile App
494 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
954 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,099 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,928
