Change brightness on recorded video
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I had adjusted the brightness on my camera the night before to the maximum brightness, however never turned it back down. I captured a video that I would like to have, however the most of it is bleached out. It starts off in regular color, then transitions into way to bright.
Is it possible to dim the existing video down so that i can see everything it captured?
- Related Labels:
Service and Storage
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Prob only using a third party video editing software... nothing will fix a video once saved ( from Netgear )
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yep. You'd need to download the video and open it in a video editor to see if it'll work. Even something like iMovie or Windows Movie Maker that are free might work. You might have an app on your phone that can do it too. It really depends on how much information is there to begin with. Good luck
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
While I agree with the above posts, the biggest issue is the compression used for the videos. If you've ever edited digital photos saved in JPEG format you'll quickly realize that there's data missing due to the lossy compression. If you had a camera that saves a raw image (straight from the sensor with no compression or manipulation) you can usually pull out more detail. Once the data is lost due to lossy compression you can never get it back.
Based on my limited experiments with these videos, it's better to leave the brightness at a daytime level and use software to brighten nighttime videos.
Arlo Mobile App
488 -
Arlo Pro 2
11 -
Arlo Smart
148 -
Before You Buy
951 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,097 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,905
