Date and Time Stamp of Recording Incorrect
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Related Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Try 2 things to get the timestamp to be proper:
1) Power cycle the base.
2) Remove the camera from Settings, My Devices and resync.
Any help?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks however I did try this this week after reading your suggestion but its still not resolving the issue. The time is still off about 35 minutes.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Im having the same issue, has this been resolved?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Are you referring to thetime noted in the library or the time noted in the filename when downloaded (in epoch time)? If you download, use www.epochconverter.com to get a human-readable time. Also, check the embedded metadata in the video to correlate the time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It has not be resolved. Now im having other issues as well. I am going to reach out to tech support the evening.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I guess the one thats noted in the library. I have the CVR going on this camera and when you try to go back to watch something thats been recorded, the time stamp is way off. So for exapmle if I know someone arrived to my house at 12:37pm and later that evening i try to see something from when they arrived, my time stamp will be off anywhere from 15-30 minutes in either direction. It could show them arriveing at 12:54pm. All i know is it's never right and its only when i try to view a CVR clip. Whats odd is if that same camera will captured a motion clip from some time in the day, that time stamp will be correct.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Open a case with support here. More cases should get things fixed faster.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
OK. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I just purchased a CVR plan today and am having the same issue. CVR timeline is about 30 minutes off, but recordings captured due to motion have a correct time stamp. Anyone receive a solution from netgear?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hey @blade929 and @FuzzyBlackCat,
Are you experiencing this issue when purchasing CVR on your account? Could you clarify with the incorrect time you are receiving for the recordings?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Make sure your Arlo devices are on the right time zone. You can check this by logging on through Arlo and go through "Settings" > "My Devices" and choose your base station to change the time zone to show the correct time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
My Arlo Pro 4 Camera's time is off by 30 minutes also.
I noticed it last week and reset the base unit a couple times.
The time zone is set ti the East coast and there is no way to set the time in this unit.
Please advise!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Same issue here with the actual time being 7:30am, but the recorded video in the Library shows 7:00am. This just started recently and I can't pinpoint anything I changed with the Arlo system. The saved video times are off when I view them via the iOS App or using Chrome on my Mac.
I could be mistaken, but yesterday I thought the video time stamps were off by about 25 minutes. I use a schedule to arm and disarm the camera. I can monitor for a few days to see if the video time stamps change to other than today's "off by 30 minutes" stamp.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The time zone is set in Settings, My Devices, your base (not the second base listing which is the siren), Time Zone.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Just confirmed that the system went into Disarmed mode at 8:00am actual time, as it should per the schedule. However, videos are still being recorded via motion detection and saved with the time stamp off by 30 minutes (video time stamp was 7:40am, but actual time was 8:10am).
I waited until 8:30am actual time and the videos stopped recording (video time stamp at 8:00am) via motion detection.
It appears there's a disconnect somewhow between the actual time and what the base station sees as the correct time. This just started for me in the past week.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If your time zone is set correctly, try restarting your base.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes, time zone is set correctly. I'll restart the base station now and see how it works at 5:00pm when the schedule goes to Armed and then check it for the next couple days.
Arlo Mobile App
491 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
954 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,097 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,924
