Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Does Arlo Pro 2 Camera require an upgraded account?
Reply
Discussion stats
  • 1 Reply
  • 739 Views
  • 0 Likes
  • 2 In Conversation
Uwantmore2
Follower
Follower
Will the Arlo Pro 2 plugged in with the power cable set to record “motion only” NOT 24/7 require a upgraded account?
Also can you create zones when plugged in and set up to record motion only?
1 ACCEPTED SOLUTION
Accepted Solutions
steve_t
Master Master
Master
Upgrades are for more than 5 cameras, longer video retention, and/or CVR (and soon Arlo Smart). So no, you won't need to upgrade your account if you merely want the camera to remain powered full time
Yes, you can create zones when plugged in. You also get the 3 second lookback feature
1 REPLY 1
steve_t
Master Master
Master
Discussion stats
  • 1 Reply
  • 740 Views
  • 0 Likes
  • 2 In Conversation
