Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Is it possible to create additional Schedule Modes?
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have "programmed" several modes for my Arlo Pro 2 cameras, and use them in conjunction with the Schedule Mode. I would like to create one or more additional schedules: one for when I'm at home, another for when I'm away from home, etc. Is it possible to create additional Schedule Modes?
Labels:
- Related Labels:
Online and Mobile Apps
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The way it is now, you can only have really one schedule...but as you know you can use any mode you create in the schedule.
Only way for two schedules would be multi bases... there is no limit as to the number of bases on any level of service... and each base would have its own. Works well if you can split the total cams into groups ( like inside / outside , etc )
Morse is faster than texting!
Related Labels
Arlo Mobile App
494 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
954 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,099 -
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,928
