- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hello
I have 2 camera Arlo Pr 2 (H3), but only one generated push email notification when motion is detected.
As the same time,both camera can be used in live view, video rewards is done I can watch all short video but without email alert.
I am in mode : geo + planning
Firmware 1.124.1.0_15483
Serial num : 52M17978AF4C8
Any idea ?
Solved! Go to Solution.
- Related Labels:
Troubleshooting
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I found it
Go to mode,
select Armed mode,
then edit each camera to specify 2 rules :
stick both records and push notification
end to re select the good mode (my case geo on mobile apps only)
Now it' s done
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Edit the rule for the camera that doesn't send emails in the mode you use and you'll see a send emails box at the bottom. Tick/check that box. Save. It should work now
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
thanks for reply,
but I have already stick option on my iphone (green case)
Mode/geolocalisation/push notification/stocked
Rodolphe
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I found it
Go to mode,
select Armed mode,
Now it' s done
Arlo Mobile App
491 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
955 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,097 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,924
