Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Orbi and Arlo compatibility
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
HI all 1. I was wondering why Arlo Pro needs a separate Hub. Could Orbi router not manage the cameras? 2. I have a Lima Cloud attached to a harddisk. Is it possible to save recordings here instead of having to got through provider Cloud? Best regards
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi.
Not sure what the rationale is when the Arlo Q connects directly to the wifi router but no, there is currently no router that can manage the Arlo / Pro / Pro 2 cameras. We used to be able to with a certain Nighthawk but that functionality was removed long ago. You must use a base station.
At this stage, you can only record to the Arlo cloud, or the Smartthings cloud if you use SHM, and/or the USB drive inserted in the back of the Pro /2 base station
Related Labels
Arlo Mobile App
494 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
954 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,099 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,929
