Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Robot lawn mower and Arlo Pro 2
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I'm looking into using Arlo Pro 2 for in my garden and home.
Is there a way to stop Arlo triggering due to a robot lawn mower mowing the grass? As robot lawn mowers tend to cut frequently and so run up to 12 hours a day, it would cause a lot of motion triggering in the garden.
Is there a way to set the sensitivity so it will ignore a small robot, but trigger when a person is there?
Labels:
- Related Labels:
Before You Buy
1 REPLY 1
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You'd have to experiment with the sensitivity settings. I'd suspect it should work but only trial and error would give you the answer. The robot and a person would have big IR differences, I would think.
Related Labels
Arlo Mobile App
493 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
954 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,099 -
Online and Mobile Apps
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,925
