Security risk Android App disarming my cameras
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Well there is my thinking "wow my arlo pro 2 is working without a false alarm, thats a first" I go outside at 2:30am to find there is no IR lights on my cameras? Looking on my app on android I see its removed my scheduals I set, and left them blank, this has resulted in my cameras being disarmed.
Netgear, you need to get your self seriously sorted out, and fast, this is not going to end well for you if your customers are left with disarmed cameras due to your system fails.
Dan
- Related Labels:
Online and Mobile Apps
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Agreed. I haven’t seen this as much recently, but there have been times when updates messed up rules, modes and apparently, schedules. I manage 29 cameras and it is not at all practical to review all of the settings after each update, even if I had a clue when the updates are taking place. All we can do is notice a problem and chase it down. Not good. Our settings should be protected more robustly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have similar experience as well. I went through one month without any issue. Then, suddenly the system disarmed on its own and I was using schedule mode. For some reasons, the schedule mode changed the setting and I did not touch anything.
So, I reset everything. A week later, it disarmed on its own again! Then, I hit Schedule mode to see if there is anything wrong and I can't see any setup issues. Then, the system is armed again.
Is this software issue? How do I know if there is an update recently that caused this issue? Or, is this due to something else?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have experienced unexplained rule, and mode changes from time to time. I have always attributed them to software updates and chastised Netgear for not allowing customers to control the timing of the updates on something so critical as a security system.
i currently use geofencing coupled with schedule and have a problem with one home where geofencing properly arms the system, but at midnight, the system appears to disarm even though the geofencing status has not changed and the mode before and after midnight is the same. I compliment the flexibility offered by the Arlo system in this area. It is the best I’ve seen on any camera system, but it needs to work reliably and the settings should not change after an update, as many people have experienced. I have 29 Arlo cameras at four locations and it is impractical to check the setttings every day to make sure a software update hasn’t changed something when I wasn’t looking. I have to notice a problem and then fix it....if I can.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Dan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
New Base station firmware has been released that should help resolve the issue being discussed here. Check your base station firmware to be sure you are up to date with the latest available version.
Take a look here for more information on this firmware: Firmware Release Scheduled 6/21 to Address IR Rapid Battery Drain and Modes and Schedules Issues
JamesC
Arlo Mobile App
491 -
Arlo Pro 2
11 -
Arlo Smart
152 -
Before You Buy
954 -
Firmware Release Notes
57 -
Google Assistant
1 -
IFTTT (If This Then That)
24 -
Installation
1,097 -
865 -
Service and Storage
317 -
SmartThings
37 -
Troubleshooting
5,924
