ARLO PRO cannot charge
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have a 3 camera kit. one of them is constantly plugged in with a genuine arlo pro charger that I bought with the system.
For 6 months this worked fine.
In the last month every time i load up the arlo app it shoes a message
"the charging source connected to the camera cannot charge your batery. Please use an Arlo power adaptor."
I turn it off, turn it on. Take the plug out. etc. nothing removes this.
I emphasise - I am using the genuine arlo charger provided in the kit.
- Related Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Have you tried running it without the battery inside for a bit?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No problem. If it turns out to be a faulty charger, I'm sure Netgear will replace it for you under warranty
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
A number of reviews online state they are not very weather proof and allow moisture in. Assuming they replace the charger, check first to make sure the battery is ok, then add a little silicone around the port after you have it plugged in. I ordered solar chargers and once they arrive, I will be adding silicone to them.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Use of the standard power supply outdoors is a sure way to void your warranty. While I'm sure you can weatherproof the connectors and the supply itself, it would be much safer, at least warranty-wise, to use the proper supply in the first place.
If you're out of warranty, give it your best shot.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have actually drilled a small hole and had a power point specifically installed on the other side (i.e on the inside).
So there shouldnt be any issues in terms of weather - unless its the point that connects to the camera.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
rmercad wrote:I have actually drilled a small hole and had a power point specifically installed on the other side (i.e on the inside).
It is at the point where it connects to the camera
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
He is using the Netgear power supply which is supposed to be indoor/outdoor....or did they remove outdoor from their advertising? I know it was there just a few days ago on amazon.
jguerdat wrote:Use of the standard power supply outdoors is a sure way to void your warranty. While I'm sure you can weatherproof the connectors and the supply itself, it would be much safer, at least warranty-wise, to use the proper supply in the first place.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
DoriJC,
The standard power cable and adapter supplied with the Arlo Pro is not designed for outdoor use. There is an Arlo Pro/Go charger designed for outdoor use available as an accessory here: Outdoor Power Adapter (VMA4700)
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I thought that's what he was using
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Nah, he said the AC adapter that came with the kit. The Outdoor power adapter is a separate purchase
Apple HomeKit
1 -
Arlo Mobile App
312 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
71 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,171 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,382 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,018 -
Videos
1
- « Previous
- Next »
