- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Do I have to shutdown the ARLO base station to use ARLO PRO base station? If I just use the ARLO base station, am I losing on many features that the ARLO PRO has (have)?
Solved! Go to Solution.
- Related Labels:
Installation
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks TomMac...
I had both set up ARLO with 2 cameras and ARLO PRO with 3 cameras, the only thing with ARLO PRO is that there is more choices of icons that shows on the bottom so I just turn ARLO off and added the other ARLO cameras without AUDIO to my ARLO PRO base station, now in business with 5 cameras working. I will save the other 2 base units that came from ARLO for another time when I decide to grow bigger.
Thanks again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No, you just need another Ethernet port.....there is no limit to the number of bases on any account level.
The only features lost on the Pro base are the siren an local USB record.... I still run 9 cam on the original Arlo base ( yes some are pros ).. The audio feature on the Pro cam still works on the original base.
The better option is to run two bases so you can really expand your coverage
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks TomMac...
Thanks again
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Never know when another base will be needed ... it is the only true way to expand your coverage.
I was using a second base for a while, and split the two between inside and outside cams... because they operate as separate systems, it gave me more flexiblity in arming/schedules
Apple HomeKit
1 -
Arlo Mobile App
313 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
71 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,171 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,382 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,019 -
Videos
1
- « Previous
- Next »
