Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi guys,
I tried to find the siren checkbox in alarm mode edit as per instructions (screenshot provided as image)... after updating the app a day ago.. I cant find the checkbox to edit the alarm anymore. So now it cant be triggered.
Has anyone got the same problem?
Any suggestions are appreciated.
Thanks heaps
Thanks heaps
Solved! Go to Solution.
Labels:
- Related Labels:
Troubleshooting
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
When editing your modes, use the Add Device button at the bottom of each rule to add addditional actions, such as turning the siren on.
5 REPLIES 5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2.5.0 android app........... siren setting in my rules is gone. I don't use the siren so didn't notice, but now that you mention it, I haven't seen that setting in a long time, forgot all about it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yup there it is. Guessing they changed that a few versions back and since I don't use siren, never noticed. They should probably update their KB article, would have saved the OP some time.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Your right!!
Interesting how we need to go about it now.. But it's there so is cool.
Thanks for your reply and solution to my problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes.. an update to their article would be great. Had me wondering for a while how to do it.
The alarm is sensitive and alot of time needs to set the right sensitivity so the siren doesnt go off when bugs go across the camera.. that can be annoying to wake up to. So I dont use much either..
Still is a great feature and now I know what's up with the mode editing.
Thanks for your reply.
Related Labels
Apple HomeKit
1 -
Arlo Mobile App
312 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
71 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,171 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,381 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,017 -
Videos
1
- « Previous
- Next »
