- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
A few days ago my Arlo Pro base station went offline and now has a solid orange power light. Using the reset button makes the three lights go green momentarily, then it's back to the single solid orange power light.
Turning it off for a minute or an hour doesn't seem to help. How can I troubleshoot this?
(Also, can the mods please ad VMB4000 to the Model field for a post)
Solved! Go to Solution.
- Related Labels:
Troubleshooting
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That's referring to the Internet LED, not power. If the power LED is ever amber after 2 minutes or so from rebooting, there's a hardware issue with either the base or the power supply.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Usu, when the system is functional and goes offline with an amber power light... it;s a hardware issue
I would try a full reset and if NG after with same issue , contact Netgear Support
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
page 8 of the manual shows a solid amber light means it's rebooting or it's not finding an internet connection but it is finding the router
Reboot your router and then make sure the base station is recognized and is not blocking the internet connection.
If not, try another cable. If your base station is less than 20' from your router move it and try again. If that doesn't work, I would contact support.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
By the same token, there's a warranty that you can, and should, avail yourself of.
Apple HomeKit
1 -
Arlo Mobile App
310 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
68 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,171 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,380 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,010 -
Videos
1
- « Previous
- Next »
