- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi all
I have just bought a VMC4330. (3 camera set) and none of the cameras will sync?
They start blinking blue when starting the process but after 30-60 secs the lighting turns amber (rapid blinking)
The Base is OK, 2 green lights, and I have contact on he PC and phone.
I have tried with battery and with power cord on the cameras.
I have tried uninstalling the Base. Resetting the Base. Nothing works.
What do I miss?
Kind regards
T_BR
Solved! Go to Solution.
- Related Labels:
Installation
Troubleshooting
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I had the same problem, as mentioned above. I got several proposals for solutions from Netgear support, none worked. Then, I realised that the problems must be that I have many different wireless items, such as sound system, smart-tv etc. Netgear support proposed that I would switch off everything, which perhaps is not the best if one wants to avoid to start sync the other items again. So, I took a long network cable and moved the base station far away into an area in my home where the other wireless systems didn't reach that good. And viola, no problem to sync. Then power off, change position for base station to where i want it, use a shorter newtwork cable, power on, and everything works. Easy as that. And, no one at the support said it. So, this is my tip - go somewhere where you signal don't cross pother signals, and do the sync. Then you can move back base station and cams where you want them working. By the way, thanks for the tips given. Most appreciated.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Most common mistake is HOLDING the base sync button.... It needs a quick push and then a sec or two later , the camera button
Open all cams to reset the camerasthen close, and one at a time retry
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Tried that already, did not help 😞
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No, I will inform the place of purchase that I will be returning the product:-(
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
T_BR, MCN
Consider relocating the base station (be sure it is away from any other wireless devices that could be potentially causing interference). Bring the camera close to the base station and attempt the sync process again. Do you still see the same results?
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
To restart the Arlo pro camera make sure to open the battery door and remove and replace the battery.
Just opening and closing the door does not do a restart.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Take a careful read through this and make sure you have followed the steps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It helps sometimes when you open up your camera's battery latch again and take out the battery and this time put it back in with a little force to make sure it comes in contact inside camera's circuitry and close it.. It did the trick and works..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi MCN
Sounds very possible. Will try before sending back.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi MCN
Tried first with turning off all wifi in the house by no luck. Perhaps because I have a router with both 2,4 and 5Mhz.
Anyhow I got a 100m cable and when to the basement, and it did the trick 🙂
Thanks
Kind regards
Thomas
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am not that technical so the cable did it for me 🙂
Apple HomeKit
1 -
Arlo Mobile App
310 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
69 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,171 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,380 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,010 -
Videos
1
- « Previous
- Next »
