Arlo pro battery won't charge 1st charge
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Related Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You can NOT use a normal USB adapter to charge the Pro camera ...it needs the one supplied with it.
It puts out dual voltage at 5 v and 9v to run or charge the pack.
If the battery is an issue, ( if you have two swap it with another camera to test ) the warranty is a year from Netgear Support
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Did they fail or did they deplete due to recording and live viewing? Spec life is based on <5 minutes of both per day. WiFi connection quality also can play into this issue.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I don't know if the batteries depleted because when I plugged them in they would not charge and the camera would not turn on. Take the battery out and the camera works fine,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Either swap at the store or open a case with support using the Contact SUpport link at the bottom here.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I had a similiar issue. Plugged the camera in but it wouldn't appear to charge. With the help of tech support, I removed the device, unplugged it without the battery for 2 minutes, plugged it in and then resynched it with the base station. This worked perfectly and the battery then showed that it was charging, the battery was at 99% and the camera would show live video. The only thing that I had to do then was readd the camera to the modes I have setup.
Apple HomeKit
1 -
Arlo Mobile App
310 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
69 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,171 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,380 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,010 -
Videos
1
- « Previous
- Next »
