Arlo|Smart Home Security|Wireless HD Security Cameras
Base station-"offline"
Responder
Estadísticas de la conversación
  • 2 respuestas
  • 3996 vistas
  • 0 kudos
  • 2 en conversación
JGMCL
Hi,
Suddenly the base station (VMB400) stopped working. I am not able to get the power back into the station.
The power chord is connected and I tried different power sources and I still can't get the power on!
Any idea how to fix it.
Thanks!
JGM
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
JamesC
Community Manager
Community Manager
JGMCL,
If you're getting no LED behavior, this could indicate a hardware issue with the base or the AC adapter. Have you tried plugging in to a different power outlet?
JamesC
Ver la solución en mensaje original publicado
2 RESPUESTAS 2
JamesC
Community Manager
Community Manager
JGMCL,
JamesC
JGMCL
Hi James,
Thanks for your prompt response!
I changed the power A/C and it worked.
Thank for your help.
JGM
