Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Dimensions for plastic anchors that are included with outdoor mount
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I recently purchased the Arlo Pro and the Outdoor Mount. I want to mount it via the plastic anchors that were included with the outdoor mount. I read on another page on the forums that the size of the pilot holes should be "very slightly smaller than the biggest diameter of the shaft of the anchors."
I want ensure that the mount is as secure as possible, can you provide the dimensions of the plastic anchors that came included with the outdoor mount?
Labels:
- Related Labels:
Installation
3 REPLIES 3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The inserts are really for drywall. If the hourse is wood just use "long enough" wood screws.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That works, I can pick up some long wood screws.
Do you know the diameter of the screws that came with the mount? Want to make sure I get the same diameter size for the wood screws.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I used 2" or 3" exterior screws, the ones with a very coarse pitch. They generally come in boxes of many. You could take the mount to the store to find ones that suit your desires.
Related Labels
Apple HomeKit
1 -
Arlo Mobile App
312 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
71 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,171 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,381 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,017 -
Videos
1
- « Previous
- Next »
