Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
How do i tURn the base station siren off?
Reply
Discussion stats
  • 5 Replies
  • 4727 Views
  • 0 Likes
  • 6 In Conversation
loopy6900
Follower
Follower
I don't want the siren going off whenever the camera is triggered to record
1 ACCEPTED SOLUTION
Accepted Solutions
SallyC
Apprentice
Apprentice
Go to Mode and select your rule. Select the edit pen and then scroll down to Turn siren ON.  If it's not checked, your siren won't sound.
5 REPLIES 5
SallyC
Apprentice
Apprentice
Bue
I don't see what you call a "rule". Nor can I find a switch to turn the Siren on/off.  I would like to access and activate  it remotely on my Iphone.  So far no successs at doing this. any other help you can offer would be appreciated.
jguerdat
Guru Guru
Guru
Modes and rules are found in the Mode tab. Check the FAQs for much more info.
If all you want to do is remotely activate the siren, it's on the Devices tab along with the cameras. There's a button to turn the siren on and off.
Riquisissimo
How do I ensure siren is always off?
TomMac
Guru Guru
Guru
edit your mode, pick camera, toggle off the siren for that camera... repeat for each camera
Morse is faster than texting!
