- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Why does my camera night infrared come on when I have the camera set to off?
Solved! Go to Solution.
- Related Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The workaround is to keep the cameras turned on and setup a custom mode. In the custom mode add a rule that includes only the cameras that you want to be armed. If you have cameras that you want disarmed do not include them in the custom mode. Then leaving all the cameras on, swtich to the custom mode you setup. Disarmed cameras will not drain the battery as long as you keep them turned on and being disarmed they will not detect motion or record video or turn the IR lights on.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
There is currently an issue with the Arlo cameras that causes the battery to drain when you turn the cameras off. Arlo has said the engineers are investigating it. The batteries drain while off because the cameras are still detecting motion when they should not be, this causes the drain. The workaround is to create a custom mode and in the custom mode create rules for cameras that you only want armed. Any camera that you wanted to be off, do not add a rule for those cameras in the custom mode. Any camera without a rule will be disarmed. Keep the cameras on, just have their state be disarmed. This will return battery usage to normal and the camreas will not detect motion, record video, or turn the IR lights on.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Wanted to add my own voice to this topic. I noticed the 2nd camera's battery was draining ridiculously fast compared to the first that I got.
I went to put it on the charger and I guess the room was dark enough I noticed the red lights came on even though the device is disabled in the app(I turn them off while I'm at home and re-activate them when I leave.) I was able to replicate the behavior by taking it into a well lit room and then into a dark room, the red lights came on each time I stepped into the dark.
What is going on?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Also, it seems to only be happening with the 2nd camera I bought, not the one that initially came with the base station.
Kind of creeping me out to think that maybe it's been recording this entire time. This needs to be addressed ASAP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I hope dawn or any other member of the team knows that this needs fixed too!
I gotta go to store today and buy some more batteries cause one of my cams (turned off) was still throwing the night time leds and draining the batteries
Ughhhhh!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The arlo should work right like it did on its own before this update ..
Just saying
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
it's becoming frustrating cause I almost have to do this twice a day since I leave my house and turn inside cams back on and so on ...
Anyways , I hope this might help for now
I forgot to do this the other day and one of my cams drained super low ::(
My cat was in the living room but cam was off but I think it's was turning the lights on
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The IR led lights coming on is just a side effect. What's happening is the cameras are still detecting motion when they are turned off. They detect motion and in a dark room that's why the lights come on. In a bright room you won't see the lights but it is still detecting motion. When the cameras are off they shouldn't detect anything.
Read this thread, post #30 is the troubleshooting I did:
There is a work around for now. Either choose the disarm mode or create a custom mode and add a rule for only the cameras you want armed. Any camera without a rule will be disarmed. Disarmed cameras will not detect motion, record video, or turn on the IR led lights and your battery usage will go back to normal.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for replying back
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If you created a custom mode and your cameras are still draining then you did something wrong. Trust me, I did hours and hours of troubleshooting on this issue. Disarming the camera works. And while it's a workaround instead of turning them off, disarming cameras via a custom mode is a normal function of the system, so your not rigging anything, your just disarming instead of turning them off.
Maybe a POE camera system, whiub is much more reliaable, might be what woudl work for you, but that will cost you about $2,000-$5000.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
That is what you said in your reply ...
that's what I'm saying as well That's happening for me too..
Anyways
I hope a real solution with update fixes everyone's stuff
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have to disagree that it's only night vision. Myself and many others in other treads on this issue had battery drain during the day, some with smartthings, some without. Common reports are batteries draining while kids are playing out in the yard or the person working in the yard, during the day, with the cameras off, and the batteries were draining. Mine drained during the day, plus, at night, I was actaually able to get the IR lights to turn off and the cameras still detected motion and drained the batteries while the cameras were off and the IR lights were not coming on.
Either way, during the day, only at night, doesn't matter. It's an issue that Arlo needs to fix, but for now disarming the cameras you don't want armed stops the battery drain. If turning off the night vision stopped the drain too then that's great, but it didn't for me.
And just to add, I didn't want to get to technical to cloud the issue, myself and a friend watched packet traffic and that's how we dermined that motion detecting was happening when the cameras were off, no matter if it was dark or light outside and no matter if the IR lights were on or not.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes correct. The problem is with the Arlo system when the cameras are turned off. If you leave the cameras on and just disarm them, battery drain will return to normal. Something changed on the Arlo side that started this issue last week. The forum moderator has escalated the issue to the Arlo engineers and hopefully they figure it out and fix the issue soon, because we should be able to turn the cameras off if we want to.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Even if my Arlo Wire-Free Cameras are switched off, the motion detection is activated and drains the batteries every time I walk through. I just noticed today that the batteries of my cameras are very low and also noticed that the motion detection is active even if the camera is switched off. Seems we had a very similiar issue back in 2016.
Does anyone has the same issue or can confirm this behavior? Looks like this issue started during the last 2 weeks.
Any ideas, how to resolve, or seeing the same issue?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Why on earth is this thread marked SOLVED?
IT'S NOT SOLVED.
This all seems like a ploy by Netflix to sell more batteries, honestly...
With my ten cameras, most of which are only reachable by LADDER... I have to get up on a ladder now to swap batteries FAR too often. Thank you, Netgear, for making this almost senior citizen drag out a ladder far more than I want to. I typically turn off the cams in areas of my yard if I am going to be working outside... so... now I have to, what? Turn off night vision? And then when it gets dark remember to turn night vision back on? Come on. I can't remember what I ate for breakfast half the time. The calendar in my Samsung S8+ is filled with reminders of things I need to do differently now and chase around with Arlo because of all the changes the past few months... these cams worked great when I first got them, now they are a frustrating annoyance most of the time... I spend more time chasing things around with my cams than anything else. And can someone PLEASE redsign the Android app? Everytime I'm in Arlo and need to adjust my brightness, swiping down on my phone activates the stupid alarm drop down tab. In general, it just gets in the way, I spend more time swiping it out of my way after its been activated more than doing anything else in the Arlo app. Ah, to go back to the good old days where everything worked, and worked FAST and virtually FLAWLESSLY... but I now wonder if this period of wine and roses was just to lure me into buying more cameras... and then once I had - BAM... bugs and issues galore...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
All I can say is that I hope people are actually calling customer support instead of just complaining, because I don't think Netgear cares. Like I said on an earlier post, I spent 2 hours on hold with tech support, only to be told that they might push out a fixed soon and would notify me in a day or so. No notification ever came. Do they even monitor these Community Support forums? This is TOTAL BS and exactly why I will be buying from Ring from now on...great cameras and great customer support. Very disappointed in Arlo.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
This thread was marked as solved by the original person who posted the issue after I provided a way to stop the battery drain, which was to disarm instead of turning off. For the original poster that solved the issue for them so they marked it as solved. The OP marked as solved, netgear didn't.
I agree about the alarm button being at the top of the android app, I pull it down by accident sometimes as well.
I like you change the brightness on my phone all the time, auto brightness doesn't cut it for me. So, for an easier way to chnage brightness on android, go to the play store and search for Brightness. Download and install the app called Brightness devoloped by Alexey Rogulin. This app lets you change the brightness on the fly, it's free, no ads, no permissions needed, just put a shortcut on your homr screen and tap it. An interface comes up instantly, not even a full app, that allows you to change the brightness. Works great.
BTW - calling Arlo support is useless. It's just a outsourced call center where they read from scripts. They have no troubleshooting skills and I doubt any issues people call in for get logged and passed on to Arlo. It's a poor excuse for 1st level support. However, JamesC, the forum moderator, has escalated this issue to the Arlo engineers. I'm an engineer myself and really have no confidence that the Arlo engineers are very good at all. Only reason I stay with Arlo for now is because they are the only cameras that fully integrate with my smart home system (smartthings & echo/Alexa). I don't blame anyone for switching to somethnig else.
Apple HomeKit
1 -
Arlo Mobile App
312 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
71 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,171 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,381 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,017 -
Videos
1
- « Previous
- Next »
