- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I cant beleive that I am unable to currently buy the new mount for my Arlo Pro Cameras!....The "old" mount blocks the USB port and nips on the silicone sleeves, the new mount has a much smaller/redesigned locking nut on it!
I have 2 cameras now sitting as paperweights until the correct mounts get released!
Solved! Go to Solution.
- Related Labels:
Installation
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ahhhhh finally received my new nuts! , and in Black as well they do exist! Now i can get my 2 paperweights installed!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
surfer1000,
If you currently own the VMA1000 outdoor security mount with the larger locking nut and you need a smaller locking nut for your Arlo Pro cameras, this can be provided by support. Please contact the Arlo Support Team. You will find several options for contacting support in the provided link.
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
surfer1000,
I apologize for the poor experience. I will review your case and request an update on the status of your replacement part. I will provide an update as soon as I can.
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi James,
I purchased an Arlo Pro set from Costco (AVM4000C), and the included outdoor mount had a "narrow and tall" plastic tightening nut (about 1/2" in diameter) compared to "flat and wide" ones I have seen for the outdoor mounts available for sale in stores and online. The nut seems better designed to not block the charge port, and also part of the nut actually fits snugly inside the thread opening (to make a better water seal?).
(for some strange reason, all online pictures of the Outdoor mount, including those on the Costco website, show the old "wider" lock nut for the regular Arlo)
It has been troublesome finding additional outdoor mounts for my Arlo Pro cameras, and I have cancelled orders left and right because I am not sure whether the tightening nuts fit correctly. So far, I have only seen Outdoor Mount part numbers VMA1000-10000S (white) and VMA1000B-10000S (black), and all of them show the "flat and wide" plastic lock nut.
Does Netgear have another outdoor mount (like the one included in the Costco bundle) with the "smaller" lock nut specifically designed for the Arlo Pro?
In addition to the resigned locking nut, it would be nice if Netgear released a mount which can actually be locked or strapped to the camera; camera theft is a big issue for me, especially since I have a single-story house with low ceilings.
FYI, there are some other threads regarding this problem as well:
https://community.netgear.com/t5/Arlo-Pro/USB-connection-and-screw-mount-on-Arlo-Pro/td-p/1158236
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
surfer1000 wrote:I cant beleive that I am unable to currently buy the new mount for my Arlo Pro Cameras!....The "old" mount blocks the USB port and nips on the silicone sleeves, the new mount has a much smaller/redesigned locking nut on it!
surfer1000, I am in the same predicament; I want to get some additional outdoor mounts (in black), to match with certain areas of my house, but can't find the Arlo-Pro redesigned style anywhere (for standalone purchase). Until then, my cameras are also paperweights taking videos of one another inside the house.
Did you buy the Arlo Pro Costco Bundle, too? It comes with the outdoor mount with the smaller locking nut, but only one set, in white.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi, no I bought a 4 pack from Amazon UK, which only has 1 indoor/outddor mount supllied. Im using this white one, and one magnetic mount so still have 2 cameras as paperweights waiting for Netgear to supply me 2 new BLACK locking thumb nuts to replace those on the old style mounts!
This cost me £820 on the 10th Febuary and here we are now on 14th March and I still have 2 of my cameras doing nothing, the lack of knowledge on this from Netgear support is atrocious!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
surfer1000 wrote:Hi, no I bought a 4 pack from Amazon UK, which only has 1 indoor/outddor mount supllied. Im using this white one, and one magnetic mount so still have 2 cameras as paperweights waiting for Netgear to supply me 2 new BLACK locking thumb nuts to replace those on the old style mounts!
The new style you mention is like this, right?
Old style like this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Without getting out my ladder, Yes...i believe that's correct.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
yes that's it the new style mount!....although I need 2 in BLACK
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
surfer1000 wrote:yes that's it the new style mount!....although I need 2 in BLACK
Good to know we're on the same page. 🙂
I contacted Netgear support, and just received a reply; it seems their solution is to send me the new plastic tightening nuts, just like your case. I guess that's all I can do for now.
On another note, have you heard anything regarding the metal used for these mounts? I saw a picture somewhere in which there was rust in the metal area just below the thread. That's not very promising, especially if it's designed to be used outdoors. Then again, there may not be any way to prevent this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
manofice wrote:Without getting out my ladder, Yes...i believe that's correct.
Thanks. Now need to get those new plastic nuts.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
They could use 316L grade stainless for the part, that would take along time to rust (10+years), I for one would pay more for that. The current part just seems to be BZP (bright zinc plate) which won't take that long to rust 2years I reckon, I live on the coast so well see.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
surfer1000 wrote:ahhhhh finally received my new nuts! , and in Black as well they do exist! Now i can get my 2 paperweights installed!
Great to hear! 🙂 I'm waiting for mine. Hope everything works out for you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
One would think Netgear could get their act together on the new outdoor mounts. They include one in the Arlo Pro 4 pack, but none in the 2 pack. Then we can't locate them at any local stores. Very poor treatment of customers who've already purchased their cameras, IMHO.
Secondly they sell a backup battery that requires a charging dock that isn't available.
I have purchased the 4 pack and a 2 pack. Had planned to purchase more for other properties I own, but will probably try another company's security cameras now. Very POOR customer treatment indeed. Lost respect for Netgear after using their networking products for years.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
proberts,
The outdoor security mount is currently available through many retailers and online, for more information click the Buy Now link here: Outdoor Security Mount in White (VMA1000)
I have requested an update on the availability of the Arlo Pro charging station, I will post an update once I have more information.
JamesC
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The one I purchased and returned to the store wasn't the same at the one that came with the Arlo Pro 4 pack. It was model VMA1000-100.
If that is the correct mount for an Arlo Pro, what are the comments about needing wingnuts with that mount?
The two photos listed above are different, just like the mount I had that came with the 4 pack and the one I bought later at the store.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
What myself and surfer1000 have done is open a support ticket regarding the mounts, and request that they send you the new nuts. After explaining the situation to support, I received them promptly.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
If that's a 1/4-20 thread, then all you need to do is go to your local hardware store and buy a stainless steel nut. It will accomplish the same thing. It's what I did with my aftermarket mount. In fact if you double up on the nuts, you can use one to hand tighten against the camera body and the other to stop the first nut from loosening.
A small rubber oring or washer between the nut and the camera body will also create a cushion and keep the nut from backing off the camera body.
Apple HomeKit
1 -
Arlo Mobile App
312 -
Arlo Pro
27 -
Arlo Pro 2
1 -
Arlo Pro 3
2 -
Arlo Secure
1 -
Arlo Smart
71 -
Arlo Ultra
1 -
Arlo Web and Mobile Apps
6 -
Arlo Wire-Free
10 -
Before You Buy
1,171 -
Discovery
1 -
Firmware
1 -
Firmware Release Notes
119 -
Hardware
2 -
IFTTT
1 -
IFTTT (If This Then That)
48 -
Installation
1,382 -
Installation & Upgrade
1 -
Online and Mobile Apps
1,266 -
Partner Integrations
1 -
Security
1 -
Service and Storage
563 -
Smart Subscription
1 -
SmartThings
39 -
Software & Apps
1 -
Troubleshooting
7,018 -
Videos
1
- « Previous
- Next »
