Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
cann't sing in arlo account
Reply
Discussion stats
  • 5 Replies
  • 2737 Views
  • 0 Likes
  • 3 In Conversation
ammore
Just bought a new arlo pro wire-free HD security camera system in syria and when I tried to register it I got a message " you are not connected to internet . please check your connection
5 REPLIES 5
jguerdat
Guru Guru
Guru
Is it possible your ISP is blocking access to arlo.netgear.com?
JamesC
Community Manager
Community Manager
ammore,
What is the LED behavior on the base station?
JamesC
ammore
I tried another ISP somewhere else but the same result
ammore
they are all yallow
jguerdat
Guru Guru
Guru
If the power LED is yellow/amber, you have a hardware issue.  Power and Internet must all be green for things to work.  Since the power LED is amber it could be the base or the power supply. You may be able to swap the system at the store or open a case with support using the Contact Support link at the bottom here.
