Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo Q Plus Continuous Recording = Free Seven Day Storage?
Reply
Discussion stats
  • 4 Replies
  • 2281 Views
  • 0 Likes
  • 2 In Conversation
Bradlington
Hello,
About to buy the Arlo Q Plus, but just wanted to check that the free seven day cloud storage covers recording 24/7? And not just clips.
Thank you!
1 ACCEPTED SOLUTION
Accepted Solutions
jguerdat
Guru Guru
Guru
You have to subscribe to CVR to get 24/7 recording. Otherwise, you just get the normal clips.
4 REPLIES 4
Bradlington
Should say I’m in the UK, in case that makes any difference.
Thanks for the help!
jguerdat
Guru Guru
Guru
Bradlington
Ok, thanks. Thought it was too good to be true. Do you know if you can program it to record to sd card for x times of the day and switch to motion clips to cloud for the other times of the day?
jguerdat
Guru Guru
Guru
No. All clips are sent to the cloud and will also record to the SD card if installed and enabled.
Discussion stats
  • 4 Replies
  • 2282 Views
  • 0 Likes
  • 2 In Conversation
