Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo Q Plus, SD Card, CVR
Reply
Discussion stats
  • 5 Replies
  • 6527 Views
  • 0 Likes
  • 3 In Conversation
juga
If I purchase an Arlo Q plus as well as a CVR plan, is there a way to set it to record continously 24/7 to both the SD card and the cloud?
1 ACCEPTED SOLUTION
Accepted Solutions
TomMac
Guru Guru
Guru
No... NTMK
The CVR fuction will record 24/7 AND the trigger events ( motion, sound ) are indicated on the time line BUT only the trigger events go to the library and the sd card
Morse is faster than texting!
5 REPLIES 5
TomMac
Guru Guru
Guru
No... NTMK
jguerdat
Guru Guru
Guru
And you wouldn't want to.  I did a manual record from live view one time for a bit over an hour and the resulting file was over a GB.
juga
A gig per hour is not bad at all. if there was an option to record 24/7 to SD card, I would pay a monthly fee for both.
juga
Will it at least do 24/7 recording to the SD card when the internet is down?
jguerdat
Guru Guru
Guru
Only if you have motion detected 24/7.  🙂  The card gets whatever is normally sent to the cloud.
Discussion stats
  • 5 Replies
  • 6528 Views
  • 0 Likes
  • 3 In Conversation
