Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo Q Plus - SD Card
Reply
Discussion stats
  • 1 Reply
  • 881 Views
  • 0 Likes
  • 2 In Conversation
Danishcow
Hello
I realize that if there is a trigger event, the camera will record to the SD card in addition to adding the video of the event to your "library" (the server) (i.e., if a sound or motion is detected). If I delete the video of the trigger event from my library (i.e., on the phone app), will it also delete it from the SD card? Or, do I have to manually take out the SD card and delete it?
Thanks
1 REPLY 1
jguerdat
Guru Guru
Guru
You would need to manually delete it from the SD card.
Discussion stats
  • 1 Reply
  • 882 Views
  • 0 Likes
  • 2 In Conversation
