Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo Q Plus won't restart
Reply
Discussion stats
  • 8 Replies
  • 3780 Views
  • 0 Likes
  • 3 In Conversation
Bluedevil
Tutor
Tutor
I recently tried to change some video settings on my Arlo Q plus and when I try to access the camera I get the message:
Your camera is currently in use. Please wait until your camera has completed the action. You can also restart your camera if the problem persists
I tried to restart the camera (from the app) and got the message: Your camera is busy and cannot restart. As I am 1500 miles away from the camera, doing a physical restart is not possible. Any other ways to force a restart remotely?
8 REPLIES 8
TomMac
Guru Guru
Guru
In the Arlo Q, Under settings, there is a RESTART BUTTON on page bottom... click on that.
That's the only way unless you can get someone to unplug it
As a PS.. did you try both a phone/device and the web browser access?
Morse is faster than texting!
Bluedevil
Tutor
Tutor
Thank you for the response.
The RESTART button at the bottom of the page is the method I have been using and is what generated the messages. I have tried by the PC and IOS (Iphone) versions - same result.
TomMac
Guru Guru
Guru
Sorry then, got nothing... it's unusal for the Q to go out like you saying.
Bluedevil
Tutor
Tutor
It's seems to be related to changing the video settings - changed video resoluton from 720p to 1080p and it just hung up. Have to wait until I'm there in June to reset it manually I guess.
jguerdat
Guru Guru
Guru
No one that has a key?
TomMac
Guru Guru
Guru
If you know you still have wifi active .... I would look into a wemo wifi power socket.
it plugs into an outlet an allow toggling on off of the ac outlet via phone...tho would allow a remote reboot via power down.
Bluedevil
Tutor
Tutor
I will have a friend go over and reset. After I visit I may just put the POE switch on a timer and have it recycle the power every night
TomMac
Guru Guru
Guru
good to hear you have a possible solution...
tho if able keep us informed of this issue... it's the first time I can think of that a Q camera has locked up from changing the settings the way you did.. possible bug with using the POE ??
Discussion stats
  • 8 Replies
  • 3781 Views
  • 0 Likes
  • 3 In Conversation
