Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo Q PoE question
Reply
Discussion stats
  • 5 Replies
  • 3855 Views
  • 1 Like
  • 4 In Conversation
Dmantrini
I own the original Arlo Q (without PoE). My question is: Can I purchase just a PoE adapter, and connect it to the unit without purchasing another Arlo Q (the newer version with PoE)?
They both seem identical...except for memory slot, (which I don't need) and PoE. I just don't want to purchase an entirely new Arlo Q unit just for PoE when the older version works fine.... Any help?
1 ACCEPTED SOLUTION
Accepted Solutions
TomMac
Guru Guru
Guru
No, they are different.
TBMK; The original uses a mini usb and the Q+ has a usb 3.0 type plug
q plus
Morse is faster than texting!
5 REPLIES 5
TomMac
Guru Guru
Guru
q plus
Dmantrini
Thanks... I just thought there was a way around having to spend $250 for another camera that I don't need. Ugh....
jguerdat
Guru Guru
Guru
FWIW, you can use a USB2.0 micro plug in a USB3.0 connector - it uses the larger portion of the two part connector.  Whether that would work for the Q+, I have no idea. In any event, the Q is WiFi-only so you'd only be able to use the PoE adapter to power the regular Q, if at all.  The Ethernet part wouldn't work in any case.
dprairie
So you can use the Arlo Q or Arlo Q plus and connect it to wi fi with no need for wires?
jguerdat
Guru Guru
Guru
Other than power via the USB power supply, correct.
Discussion stats
  • 5 Replies
  • 3856 Views
  • 1 Like
  • 4 In Conversation
