Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Arlo SD solely
Reply
Discussion stats
  • 1 Reply
  • 2343 Views
  • 0 Likes
  • 2 In Conversation
cilice
Follower
Follower
Hi all,
I just bougth an Arlo Q plus camera for a research protocol in order to evaluate the activity in a "wild" environment (internet is not available).
I thought that I could record and save continuously the video on the SD card, but I only have a record when an event occur...
Is it possible to activate CVR on SD?
Thank you for your answer.
1 REPLY 1
TomMac
Guru Guru
Guru
Not to my knowledge....
The mem card is a backup if the interent goes down... it will record motion detected movement at the same time it is sent to the cloud.
The CVR option relies totally on the cloud recording ( and that does not go to the mem card )
Morse is faster than texting!
Discussion stats
  • 1 Reply
  • 2344 Views
  • 0 Likes
  • 2 In Conversation
