Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Blue/Green Lines on Timeline
Reply
Discussion stats
  • 1 Reply
  • 2234 Views
  • 0 Likes
  • 2 In Conversation
Danishcow
Hello
Technical question:
If I delete from the library videos that were triggered by a motion (green) or sound (blue), would those green/blue bars be removed from (above) the CVR timeline as well? I'd like them to stay for points of reference...
Thanks
1 REPLY 1
TomMac
Guru Guru
Guru
No, the bars showing a sound or motion trigger will remain on the CVR... they are really two diff recordings that come from the same event.
BUT, I recommend you do NOT delete files, as the auto delete feature will take care of them at the time limit of your service level.... It's hard to get something back if wanted after doing so and more time lets you decide if it should be downloaded for saving.
Morse is faster than texting!
Discussion stats
  • 1 Reply
  • 2235 Views
  • 0 Likes
  • 2 In Conversation
