Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Incorrect time zone of library recordings
Reply
Discussion stats
  • 4 Replies
  • 3741 Views
  • 1 Like
  • 3 In Conversation
abdelrahman
Tutor
Tutor
Both my Arlo Q Plus POE has the wrong time stamp for all recordings in the library. They are an hour later, which is UTC +03:00. Although I have set both devices' time zone to UTC +02:00 Cairo. I have also tried restarting the devices with no success.
Please advise how to fix this issue?
Thank you in advance,
4 REPLIES 4
jguerdat
Guru Guru
Guru
Open a case with support.  It may be a coding error in the timezones.
DanielT
Arlo Employee Retired
I am escalating abdelrahman's Support case to Engineering.
abdelrahman
Tutor
Tutor
Hello,
I have just realised something very weird.
The time stamp is correct on my mobile but wrong on the web. So basically Arlo's app from AppStore on Android has the correct time but https://arlo.netgear.com/ on the web has the wrong time for videos in the library.
jguerdat
Guru Guru
Guru
Is the timezone on the computer set properly?
Discussion stats
  • 4 Replies
  • 3742 Views
  • 1 Like
  • 3 In Conversation
