Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Once a motion is detected, what's the maximum length of the recorded clip?
Reply
Discussion stats
  • 2 Replies
  • 1185 Views
  • 0 Likes
  • 2 In Conversation
ldm1417
Hi All,
Let's say the motion continues for 30min. Will the camera make full (no time lapse) recording for the whole 30min?
Thank you!
2 REPLIES 2
TomMac
Guru Guru
Guru
Once motion is detected it will continue for ether the fixed set time ( max 120 secs ) or till movement stops 300 secs
When the max is reached in either case, the motion detector resets ( about 5-10 secs ) and it starts over again.
If you use the CVR paid option, the Q will record 24/7
Morse is faster than texting!
ldm1417
OK, so if I don't use CVR, I will have the same thing but with 5-10 sec gaps (motion sensor's reset time).
So, if there is continuouse motion, then the cam will record clips of 5min each one (300sec) with 5-10sec time gaps between them.
Correct?
Discussion stats
  • 2 Replies
  • 1186 Views
  • 0 Likes
  • 2 In Conversation
