Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
POE adapter distance from Arlo Q plus
Reply
Discussion stats
  • 2 Replies
  • 3985 Views
  • 0 Likes
  • 2 In Conversation
home_alone
Hi,
The POE adaptor will not fit the intended spot for the camera, but the pictures of the back of the camera are not detailed. Can I pull a Cat5 to the Arlo Q Plus with the POE adaptor on the other end of the wire, ie: close to the POE switch?
Thx
1 ACCEPTED SOLUTION
Accepted Solutions
TomMac
Guru Guru
Guru
Don't think so.... I think the Poe adapter plugs in via a USB 3 type plug into the camera
Morse is faster than texting!
2 REPLIES 2
TomMac
Guru Guru
Guru
home_alone
Thanks!
Discussion stats
  • 2 Replies
  • 3986 Views
  • 0 Likes
  • 2 In Conversation
