Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Q Plus - can it be powered by net gear nighthawk Ethernet connection?
Reply
Discussion stats
  • 5 Replies
  • 4003 Views
  • 0 Likes
  • 4 In Conversation
Gedhols
  1. The net gear nighthawk 4g modem has an Ethernet port.... sometimes these ports may not have all wires connected. Does anyone know if it does have the power wire so it could power an Arlo Q Plus?
5 REPLIES 5
steve_t
Master Master
Master
Are you referring to the Nighthawk M1?
Gedhols
Yes, the Nighthawk M1
jguerdat
Guru Guru
Guru
Without full specs it's hard to say.  The hotspot would need the Ethernet port to support PoE - if the specs don't mention it then it likely doesn't.  However, you could use a switch the support PoE and connect that to the M1.  The Q+ would then connect to the switch and draw power from it.
JamesC
Community Manager
Community Manager
Gedhols,
The Nighthawk M1 does not support power over ethernet. As jguerdat mentions above, a PoE switch would be needed.
JamesC
Gedhols
Thanks for the information
Discussion stats
  • 5 Replies
  • 4004 Views
  • 0 Likes
  • 4 In Conversation
