This topic has been closed to new posts due to inactivity. We hope you'll join the conversation by posting to an open topic or starting a new one.
Recording without WiFi
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi All,
It seems with Arlo Q Plus, recording is possible without WiFi...
If camera is not connected to the WiFi, all the recording is done in the loop on the SD-card.
Is that correct?
Thank you!
- Related Labels:
Before You Buy
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The only way to view recordings made on an SD card it to eject it and use a PC.
The manual says "you can use an SD card as a backup location to store recordings". It says nothing about using a card as an alternative to the cloud.
As I see it, no cloud = no recording.
Just another user
Arlo hardware: Q Plus, Pro 2 (X2), Pro 3 (X3), Pro 3 Floodlight, Security Light (X2), Ultra (X2), Doorbell, Chime
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It's definitely a backup device but recordings will occur. As noted, you have to remove the card to view on a computer and you won't be able to do anything with the camera since there's no Internet connection.
It can be done but with very limited utility.
