Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
Simultaneous Live View Possible?
Reply
Discussion stats
  • 1 Reply
  • 2086 Views
  • 0 Likes
  • 2 In Conversation
johnhwang
Follower
Follower
I was wondering if there any models that support multiple accounts, primary and/or guest, viewing the live feeds simultaneously. I was planning to purchase arlo q plus (for the POE) portion and possibly using some of the wireless arlo/arlo pro but I need to be able to live view simultaneously. I've searched through the forums but it appears that its not supported so I wanted to make sure before I spent a good chunk of change.
1 REPLY 1
TomMac
Guru Guru
Guru
If I understand you correctly... The Q Plus would do it.
There can only be ONE primary account holder.  BUT, if you grant others access (GRANT ACCESS in settings ) multiple users can view at the same time.You also have some control over their admin privileges
Multi users on the PRO and Arlo can be an issue because if they are on battery, more users viewing can run the batteries flat in a short time ( tho the pro can be AC powered )
Morse is faster than texting!
Discussion stats
  • 1 Reply
  • 2087 Views
  • 0 Likes
  • 2 In Conversation
