Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
What's the best range extender for Costco Arlo?
Reply
Discussion stats
  • 1 Reply
  • 3376 Views
  • 0 Likes
  • 2 In Conversation
Mikemur
Follower
Follower
I need to extend the range so that the cameras in my gardens can connect with the base station.  What's the best extender, with firmware that is known to work?
1 REPLY 1
TomMac
Guru Guru
Guru
Yon can not extend the range of your cameras with a wifi extender .... The only way to really expand your coverage is by adding a second base unit.
But , what you can do is centrally locate the base using an extender so the base has a better connection to all yor cameras if you don't do the first option.
Most any of the extenders on the market will work as long as they have an Ethernet port ( for the base) and thruput over 1 Mbs
Morse is faster than texting!
Discussion stats
  • 1 Reply
  • 3377 Views
  • 0 Likes
  • 2 In Conversation
