Arlo|Smart Home Security|Wireless HD Security Cameras
× Arlo End of Life Policy Notice
To view Arlo’s new End of Life Policy, click here.
blue light comes on when I power up but it won’t find my iPad when I try and discover
Reply
Discussion stats
  • 5 Replies
  • 4435 Views
  • 0 Likes
  • 3 In Conversation
NeilA
I can’t get the camera set up, the blue light comes on when I power up but it won’t find my iPad when I try and discover - tried factory reset but to no avail
5 REPLIES 5
TomMac
Guru Guru
Guru
you are putting in your main router info ??
Morse is faster than texting!
NeilA
I am plugging directly into my router
TomMac
Guru Guru
Guru
The Q cam can plug into your router.... or It hooks into you home wifi system only via wifi...
If running on ethernet only connection , you must have the POE active if not using external power
It will not work plugged into a laptop.
NeilA
I am not using POE as router output aren’t powered, so have Ethernet cable connected directly to router and then power into the Ethernet connector via the usb power lead
JamesC
Community Manager
Community Manager
NeilA,
What do the different LED behaviors on my Arlo Q camera mean?
A solid blue LED means the device is already connected to the Arlo servers. Has this camera ever been on another account?
JamesC
Discussion stats
  • 5 Replies
  • 4436 Views
  • 0 Likes
  • 3 In Conversation
