Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
802.11x
Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Retired_Member
Not applicable
2017-05-16
06:29 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can you please confirm if the Arlo Q is 802.11ac compatible. Is there an Ethernet port too?
Thanks
Labels:
- Related Labels:
Before You Buy
3 REPLIES 3
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
The Q is 802.11 on the 2.4 and 5 ghz band
The Q Plus has an ethernet cable adapter and can run as POE too
Morse is faster than texting!
Retired_Member
Not applicable
2017-05-16
07:30 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Appreciate the response. Does that mean it is 802.11n only?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It's 802.11ac compatible in the sense that it will connect to such a router but that doesn't mean it uses that capability. It uses 802.11n since that's more bandwidth than it can use, just as the Pro bases use 100Mb/s Ethernet as well as USB 2.0.
Related Labels
Activity Zones
1 -
Apple TV App
1 -
Arlo Mobile App
20 -
Arlo Pro
1 -
Arlo Q
30 -
Arlo Smart
2 -
Arlo Web and Mobile Apps
1 -
Arlo Wire-Free
5 -
Before You Buy
108 -
Fehlerbehebung
1 -
Firmware Release Notes
15 -
IFTTT (If This Then That)
7 -
Installation
352 -
Online and Mobile Apps
135 -
Online und mobile Apps
1 -
Other Discussions
1 -
Service and Storage
2 -
Smart Subscription
1 -
SmartThings
5 -
Troubleshooting
1,112 -
Videos
50
- « Previous
- Next »
