Arlo Q low wifi range
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I have 2 Arlo HD and 1 Arlo Q. The Arlo Q has very low range for its WiFi signal, is that normal? If i setup the camera in the hallway it is only about 5 meters from my router and barly has a signal. If i move the Arlo Q to my living room where the router is only 6-7 meters from my Arlo-Q it want connect at all. It seams that maximum distance is about 3-4 meters from any router. All my other cellphones and pc connects with good quality all over our house. I have restarted the Arlo Q several times and made new connections. Is this normal range?
- Related Labels:
Troubleshooting
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Yes, I have found the Q camera has LESS range compared to the Arlo cameras...
Tho that range is a bit low...it also depends what the signal goes thru ...like metalduc work, mirrors, etc
Can be two other reasons;
1) just not as good receiver/transmitter setup
2) the Q can work on 5 ghz too and the normal 2.4ghz on the Arlos has a better range/distance... If the Q locks into the 5 ghz ( if you have it ) you can get less range
Morse is faster than texting!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
KjetilTom wrote:I have 2 Arlo HD and 1 Arlo Q. The Arlo Q has very low range for its WiFi signal, is that normal? If i setup the camera in the hallway it is only about 5 meters from my router and barly has a signal. If i move the Arlo Q to my living room where the router is only 6-7 meters from my Arlo-Q it want connect at all. It seams that maximum distance is about 3-4 meters from any router. All my other cellphones and pc connects with good quality all over our house. I have restarted the Arlo Q several times and made new connections. Is this normal range?
No, it shouldn't be the normal range. The data sheet for the product is same as Q+ and wireless - they say wifi range is 300 feet line of sight.
Turn in a Support ticket from the Support menu.
Activity Zones
1 -
Apple TV App
1 -
Arlo Mobile App
20 -
Arlo Pro
1 -
Arlo Q
30 -
Arlo Smart
2 -
Arlo Web and Mobile Apps
1 -
Arlo Wire-Free
5 -
Before You Buy
108 -
Fehlerbehebung
1 -
Firmware Release Notes
15 -
IFTTT (If This Then That)
7 -
Installation
352 -
Online and Mobile Apps
135 -
Online und mobile Apps
1 -
Other Discussions
1 -
Service and Storage
2 -
Smart Subscription
1 -
SmartThings
5 -
Troubleshooting
1,112 -
Videos
50
- « Previous
- Next »
